TwinTurbo.NET: Nissan 300ZX forum - The weep hole under the diaphragm can leak a tiny bit
LitlElvis
on January 08, 2025 at 8:40 PM
Are the OE recirs supposed to leak air on a leak test..
posted by Z-line
on January 07, 2025 at 03:25 PM
because of the valve's internal clearance to the guide. I would say a small amount of leakage at the weep hole is normal.
Z-line
15:25:57 01/07/25
Don't think so, at least not enough to really hear it
Polishzx
18:25:17 01/07/25
I can definitely hear it if I lean in, the cloud of smoke..
Z-line
21:17:30 01/07/25
Nope. Do you have other recircs you can test? (n/m)
vorpalZed
09:13:20 01/08/25
Fortunately, I do. I’ll be swapping them this week..
Z-line
12:17:37 01/08/25
Leaking recirculation valves will result in a boost leak.
cherry
11:32:01 01/08/25
Dumb follow-up questions ;-)
ZXoltan
11:57:30 01/08/25
Mine was leaking from the weep hole, which I think
cherry
13:48:02 01/08/25
Thanks. Makes sense.
ZXoltan
14:01:27 01/08/25
The weep hole under the diaphragm can leak a tiny bit -
LitlElvis
20:40:08 01/08/25
Should the diaphragm still hold pressure or vacuum above it?
ZXoltan
08:02:32 01/09/25
